Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to create a tapered cylinder
5 REPLIES 5
mdhan82
1163 Views, 5 Replies
I'd greatly appreciate any assistance with for a novice who is trying to create a "tapered cylinder". That is, I want to make a cylindrical object where the diameter of one end differs from the other. Will I have to start with a cylinder (or cone) primitive and somehow modify this? Thank you very much in advance, and a belated happy New Year to everyone.
5 REPLIES 5
hfcandrew
in reply to: mdhan82
hfcandrew
Option A)
Select the top face > Modify > Soft transform
Change the falloff, and play around with the different settings:
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-AF536B4D-4BCF-41EF-AD66-38A3E161E467
Option B)
Select the top face > Face Transform
Pull the face up, click and drag on the white square to make it
bigger/smaller, then use plane cut to cut off any excess.
CGBenner
@mdhan82 Did the information provided by @hfcandrew answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
mdhan82
in reply to: CGBenner
Thank you so much for the help!!
Toothcentral
in reply to: hfcandrew
Thanks, this works perfectly! I wanted to make an extension adapter to a large mouth funnel (think canning and fruit preserves) to be able to use it for for smaller jars, but have the big opening to reduce spillage.
