Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to combine adjacent surfaces?
3 REPLIES 3
jamesg
2112 Views, 3 Replies
This is all one body - The edit, make solid command gets me close but I still wind up with a whole bunch of internal stuff and stagaltites that I can't get rid of.
I also have the two pieces as separate bodies in the same .mix file.
https://forums.autodesk.com/t5/inventor-forum/style-library-quot-damaged-quot/td-p/2392247
https://forums.autodesk.com/t5/inventor-forum/i-beg-you-autodesk/m-p/5539897
3 REPLIES 3
hfcandrew
in reply to: jamesg
Edit > Separate shell, maybe Analysis > Inspector, maybe 50 other ways.
Going to need a lot more info, do a screencast and as always the .stl file too.
MagWeb
in reply to: jamesg
Maybe this trick helps to join adjacent shells:
If there are two or more shells combined to a single objects as
Go to EDIT/MakeSolid. Set its SolidType to Accurate. Now you can set a positive OffsetDistance big enough to bridge the gap between the shells:
This result being the active object run MakeSolid in Accurate mode again. This time set OffsetDistance to the negative value you used in the step before:
The result should match to the source object but with smoothed valleys. You may refine that result setting the source object as a target and use either SCULPT/Attract brush or selection based SELECT/Edit/AttractToTarget:
Right bunny attracted to the source via Attract brushRight bunny attracted to the source via Attract brush
Gunter Weber
Triangle Artisan
jamesg
in reply to: MagWeb
Thanks for the ideas everyone will be working on this all week and will report back!
