Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How to adjust mesh for 3d printing
2 REPLIES 2
rafaluis
366 Views, 2 Replies
A big problem in 3d print are the slices softwares, because this softwares need to change your model in slices, some models dont have a good mesh, making slicing difficult the software.
But one the way the to correct this problem, is to change model mesh.
How to change the model mesh without change geometri the your model ?
In Meshmixer, you can select the area with low resolution, comform 1 picture.
After you select the tool "Remesh", the select the trhee optins in the tool, comform the 2 picture.
x - Preserve Group Borders
x - Smooth Group Boundaries
x - Preserve Sharp Edges
On top, adjust the densit you mesh, comform you need, after the click in "Accept".
Have a good 3d prints.
2 REPLIES 2
hfcandrew
in reply to: rafaluis
Did you have a question or were you simply just making an informative post about the remeshing tool?
Either way, here is more info: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-6EF8ABD4-AB4A-426F-A0C4-DE96FAABF520
rafaluis
Yes, I simply just making an informative post.
