Guess that's an intern oral scan viewed from below the printer's build volume.
Hint: You can hide rendering of the printer via menu: View>ShowPrinterBed.
So it should be something like this:
First thing you should do is to run ANALYSIS/Inspector on a scan. Do NOT do AutoRepair but manually click all marker spheres but the one pointing to the main boundary.
Now crop off not needed surfaces running EDIT/PlaneCut. Cut at the bottom
and at the rear
Now hit Ctrl+A to SelectAll (the object should be orange totally) and do Modify/SmoothBoundary (this is optional but should give a nicer extrusion):
Accept and run Edit/Extrude with the shown settings (Offset needs to be more than you'll need):
Accept and leave SELECT. Run EDIT/Hollow (here at a wall thickness of 2mm):
Use EDIT/PlaneCut to crop off the base wall:
Done.
