Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
How do I repair this mesh flaw?
1 REPLY 1
d-g-carey
228 Views, 1 Reply
How do I repair the flaw shown below. I tried bridge but just received a fatal error.
Labels (1)
1 REPLY 1
MagWeb
in reply to: d-g-carey
You might SELECT the wrong surface using the selection brush and run Edit/EraseAndFill.
If this doesn't reconstruct the desired surface you need to do it step by step using some bridges:
  1. Discard the selected wrong area
  2. Select exactly two regions at the new open boundary and on opposite sides of the hole and run Edit/Bridge.
  3. Use ANALYSIS/Inspector to fill the open boundaries. If Inspector highlights the boundaries in red you need to increase the mesh density of the bridges first. (>Select/Edit/Remesh)
Gunter Weber
Triangle Artisan
