Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Holes in mesh
3 REPLIES 3
169 Views, 3 Replies
Holes in mesh
Dear all,
I am using Meshmixer for my thesis project. The goal is to segment a part of an STL. However, I noticed that the model has some holes that prevent me from continuing my project.
Is there any way to suppress the holes by getting a homogeneous mesh?
Thank you in advance for your help.
Best regards,
Sofia Gonçalves
3 REPLIES 3
hfcandrew
in reply to: 1161189
in reply to: hfcandrew
I appreciate your help.
However, I have already tried that tool, and it did not work. Perhaps I am mistaken about where the problem is being created since I am using another software after Meshmixer.
fred_dot_u
Can you present a screen capture to represent the holes? There may be other methods beside inspector to accomplish your objective or there may be a mitigating factor preventing Inspector from working as desired. One option you may have is to use the select tool to outline the hole(s) and follow up with Edit, Erase and fill. It may be necessary to use Inspector to clean up remaining defects.
