Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Folder of my parts
2 REPLIES 2
skergeth
811 Views, 2 Replies
Folder of my parts
Hello to all,
i have created some objects and stored it to meshmix > my parts.
I would like to syncronise this folder with my notebook but can not find the path.
Where to find it ?
Thanks 🙂
2 REPLIES 2
MagWeb
in reply to: skergeth
At a default installation of MM the path is
C: (or MacOS)/Users/YourName/Documents/meshmixer/libraries/parts/user/My Parts
You may organise your parts adding different folders in the user directory (let's say some "Plants" folder). You might move a bundle of part files belonging together (eg: a something.obj + something.obj.png + something.obj.prt) from MyParts to such a "Plants" folder via file browser. MM will show this folder after a new start.
MM will add a new part you create to the last used folder on the user level.
You might also move important folders containing part bundles from
to
C: (or MacOS)/Users/YourName/Documents/meshmixer/libraries/parts/default
The only difference of these locations is that one can't discard parts stored at default via RMB-click in MM.
You might also remove not needed folders from default via file browser.
Gunter Weber
Triangle Artisan
skergeth
in reply to: MagWeb
Works great.
Thanks a lot 🙂
