Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
fill a large hole with planar surfaces
2 REPLIES 2
ronaldsanders21
980 Views, 2 Replies
i have a scanned face mesh that took a long time to repair, fill small holes and weird torus mesh shapes, etc. However, i did not scan the upper back and the entire back of the head. I cleaned off some messy boundaries by plane cutting three times to create clean planar boundaries. see below:
so now how to fill this large hole with preferably four planar surfaces? autofill and 'erase fill'  obviously don't work. Help is appreciated.
2 REPLIES 2
MagWeb
in reply to: ronaldsanders21
To fill such a hole in MM would need some guiding bridges (SELECT/Edit/Bridge) to subdivide the hole (> mmHelp on Bridge). Something like:
Once you simplified the hole that way you can fill the remaining holes using ANALYSIS/Inspector.
Maybe easier to SelectAll of the mask, extrude it to flat and cut this watertight mesh afterwards:
Gunter Weber
Triangle Artisan
ronaldsanders21
in reply to: MagWeb
sorry about late reply, i think your methods will both work, but both the bridging and extrude command are hidden inside the edit submenu....took me forever to find them. the help link you posted was dead, too...i viewed some tutorials before posting here and learned about bridging but gave up after failing to find it.
A UX problem it looks like. Thanks a lot.
