Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
EXTRUDE retains original surface AND new surface
1 REPLY 1
jrichards
228 Views, 1 Reply
Select > Edit > Extrude
Original surface is also retained.
How to delete original surface and retain only the new surface?
1 REPLY 1
MagWeb
in reply to: jrichards
Running Extrude the only case I know where MM keeps the original surface is if you totally select a non watertight surface (e.g. the default plane object). In this very case the original surface stays selected and you can get rid of it easily by hitting X.
Gunter Weber
Triangle Artisan
