Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Exporting split models as wildly different sizes
1 REPLY 1
Gellick
203 Views, 1 Reply
Hello, I'm trying to split a model for a multi-colored print with meshmixer, but when I export them as seperate models, one file (the one thats supposed to be the smaller peice) ends up being 3x the size of the other one, and I cant seem to properly scale them to fit together again.
Is there any way to have them export as the correct sizes? They appear in meshmixer as correct, its only when I press export and open them anywhere else that they're the wrong size
1 REPLY 1
MagWeb
in reply to: Gellick
Hmm, can't reproduce your issue.
Which format do you use on export?
Maybe there's some "scale up to a similar size" in the software (which?) you import the export result to?
Gunter Weber
Triangle Artisan
