Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
cutting stl's, adding aligning pins for 3d printed parts
2 REPLIES 2
3ddruckowski
414 Views, 2 Replies
Hi
I am in the process of cutting the stl file to put a pin and a hole on the resulting surfaces. It looks easy on youtube, but it doesn't fit when I move primitives onto the surface.  The surface of the object (square or cylinder) is never parallel to the main object/surface I am adding it to.
Cutting process looks like: Edit - Plane cut  - Cut type - Slice, Keep both. Then Edit - separate shells
Is there a setting or step I'm missing?
2 REPLIES 2
hfcandrew
in reply to: 3ddruckowski
@3ddruckowski
Looks parallel to me, but had to see from an image. Can you post your .mix file or make a screencast.
nkloski
If you want a dropped Primitive to be at a 90 degree angle to the main object, do this:
-Use the drop pivot target (with link to target) where you want your primitive to end up.  Snapping "to vertex" will have the pivot pointing along the normal / directly away from the mesh
-meshmix a primitive in and size it accordingly (it will create a new body if you don't drop it on the mesh, but rather somewhere on the background).
-drop another pivot on that new object (again with link to target turned on)
-simply drag from the new pivot to the old pivot and the new primitive will align at a 90 degree angle.
Nick Kloski
