Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
cutting multiple walls
1 REPLY 1
kswedding2010
193 Views, 1 Reply
Hello everyone,
I am stuck! I have patterns in an item that I want to remove on both the outside and the inside layer.
If i select and delete, only the outside layer is deleted, leaving the inner layer still solid.
Using shapes is far too much work, I just want to be able to delete both the outside and inside of the gauntlet at the same time, is this possible?
Jessedart
1 REPLY 1
hfcandrew
in reply to: kswedding2010
Yep. The solution might involve a workflow of: plane cut, separate shells, discard, close cracks, bridging, inspector.
Every mesh and model is so different I cannot picture what you mean, it is hard to give exact instructions to an unknown scenario. Could you: 1) Post a screencast (with a spoken explanation or written post) and 2) Post the .stl
