Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Changes to Single Dimension of Scan
1 REPLY 1
211 Views, 1 Reply
Is there a way to numerically change a single dimension of an .obj?
Using the Units, I've only been able to scale all coordinates. I would prefer not to use the free transform as I know the specific size one coordinate needs to be.
thank in advance!
1 REPLY 1
MagWeb
EDIT/Transform allows numerical input simply clicking and editing the displayed values. To scale non uniform you need to disable UniformScaling. Simply set some SizeX, SizeY or SizeZ.
Scaling happens towards the widget's center which is the bounding box's center. If you want to scale towards a certain point you need to create and transform a Pivot to that location. Once you got that pivot  and run Transform on your source object: Clicking the pivot makes the widget snap to that point
Gunter Weber
Triangle Artisan
