Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Cannot add Stencil to Meshmixer
1 REPLY 1
bikepacker
235 Views, 1 Reply
Hello All
I am trying to add a stencil in Meshmixer and I am having no success.  I go to sculp, switch to surface, click on Stencil, click on the "+" button....I then choose my file, open and it goes back to the main page and nothing has changes. the Stencil has not been imported.  There are no additional stencils in  the stencil pop-out.  I have tried JPG and PNG nothing changes. Invisible background doesn't help.  Any ideas?
Thank you
1 REPLY 1
MagWeb
in reply to: bikepacker
Hmm, basically the Stencil import is pretty robust. Are there some characters in your language which are not used in English language? Something like "ö", "ü", "ä" in German language. If yes: Check the path to the image file and remove such chars.
You might also try to put the images into MM's library manually while MM is shut down:
Simply copy and paste the image into Documents/meshmixer/libraries/default_brushtex
Gunter Weber
Triangle Artisan
