Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Can you change the orientation of the Transform tool?
1 REPLY 1
alanFM6A9
336 Views, 1 Reply
Sometimes I'm working with an object and the transform tool is not aligned the way I would like it to be.  For example a cylinder and the tool is 31 degrees off of perpendicular to one of the flat surfaces.  Is there a way to align it how I want?
Thanks, Alan
1 REPLY 1
hfcandrew
in reply to: alanFM6A9
No. You either click the green 'L' on the widget for a local framing coordinate which is automatically generated by MM using the object's bounding box. Or click on the 'W' for a orthogonal world framing.
You could try Select all>Deform>Transform.  That often brings up another automatically generated transform coordinate.
