Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Can't set Hole fill mode in inspector with mmapi.
2 REPLIES 2
eliot543
201 Views, 2 Replies
I can't set hole fill mode in inspector tool trough mmapi, in StoredCommands.h it shows that to change hole fill mode to minimall fill "replaceType" needs to be changed to 0, it doesn't show values for each mode in inspector description but I found it in erase, there is replaceType: integer values: MinimalFill = 0, FlatRefinedMesh = 1, MVCPlanarDeformation = 2 I assumed I can use them the same in inspector. Setting AppendToolParameterCommand("replaceType", 0) does nothing.
Appreciate any help.
Labels (1)
2 REPLIES 2
MagWeb
in reply to: eliot543
It's just an issue of UI updating:
mm.begin_tool(remote, 'inspector')
mm.set_toolparam(remote, 'replaceType', 2 ) # 0=MinimalFill, 1=FlatFill, 2= SmoothFill
works, but the dropdown isn't updated. So if you do a AutoRepairAll or click a marker it will be filled smooth while the dropdown still shows default FlatFill. Try it ...
As soon as you pull the SmallThresh slider it is updated correctly.
Just in case you want a correct UI for user actions you might fix this update issue via code to update the dropdown doing the same:
#cur_val = mm.get_toolparam(remote, 'smallComponentThreshold') # store current value if needed
mm.set_toolparam(remote, 'smallComponentThreshold', 0) # change the slider to zero
#mm.set_toolparam(remote, 'smallComponentThreshold', cur_val) # reset it to current value if needed
Gunter Weber
Triangle Artisan
eliot543
in reply to: MagWeb
Appreciate the help.
