Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Can not connect to Internet.
2 REPLIES 2
dlw45
952 Views, 2 Replies
When starting MM, the error 'Can not connect to Internet' pops up.
Is using a VPN a problem?
W10 recognizes the Anycubic I3 Mega.
What else might be the problem.
dlw
2 REPLIES 2
Andrew.Sartorelli
in reply to: dlw45
Hi @dlw45,
The "Unable to connect to internet" error message is a known issue with Meshmixer 3.4. To resolve the problem you can go into settings and turn off automatic check for updates or you can install Meshmixer 3.5 which has removed the option completely.
Best Regards,
Andrew
Andrew Sartorelli - Autodesk GmbH
dlw45
in reply to: Andrew.Sartorelli
Thank you for replying.
Meshmixer 3.5 is downloading.
dlw
