Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Boolean Difference, stuck on Level 1 - refining
4 REPLIES 4
ilja.coveliers
2559 Views, 4 Replies
I'm new to Meshmixer.
I have created 2 objects in Fusion360, that I would like to join together in Meshmixer with pins.
So in Meshmixer I imported my 2 Fusion360 .stl files and from the left menu I choose the pin and positioned it inside the object. Then I choose the object and with holding shift down, I choose the pin.
Now I can choose Boolean Difference, it begins and it's stuck on "level 1 : Refining"
I have a new pc since this weekend, that's alot more powerful, than my old one. And my old one never crashed when doing Boolean difference.
What can be done to remedy this problem ?
Can anyone help me with this ?
Thanks in advance.
4 REPLIES 4
hfcandrew
in reply to: ilja.coveliers
Are any of the boolean tools working? https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-355503DE-889B-4168-8398-084F9BBD508B
How complex is the shape?
What is the triangle count?
Please attach your .mix (as a zip)
ilja.coveliers
in reply to: hfcandrew
Hi, it's a basic rectangle shape.
Where can I see the triangle count ?
I found out that when I go to the edit menu and choose "make solid", that after that it no longer crashes.
Is that normal ?
I even tried to do a boolean difference from 2 random items from the "meshmix" menu and even then it crashes.
Maybe there's a simple explaination as to why it's crashing.
I hope this can be fixed, cause otherwise I must always do the "make solid"
Thanks in advance.
Greetings,
ilja
hfcandrew
Triangle count is in the bottom right.
Often remeshing the object fixes boolean failures.
If you can't do a boolean on a default object, something is wrong, but sorry don't know why.
ilja.coveliers
Vertices : 1204
Triangles : 2404
I'll try "remeshing", maybe that's better than "make solid",
because the model isn't exactly the same after using that.
Thanks for the help so far.
