Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Boolean difference leaving bumps
2 REPLIES 2
ruimjpedro
350 Views, 2 Replies
I'm trying to cut a hole on that object, but after playing around with the boolean difference that's the best/sharp cut I can get, it leaves some small bumps in the corners.
Any tips for this case ?
2 REPLIES 2
MagWeb
in reply to: ruimjpedro
Simple trick:
If you do a BooleanDifference object A minus object B run EDIT/GenerateFaceGroups on object B first (defaults should do the job)
This hardens the edges for BooleanDifference.
Gunter Weber
Triangle Artisan
ruimjpedro
in reply to: MagWeb
Hi
Although it's not perfect it seems to get a better cut, still few minor bumps but i guess i can live with them.
