Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Black spots on surface
4 REPLIES 4
andreasperti_2022
461 Views, 4 Replies
Hi how can i solve these black spots on surface when i open meshmixer?
4 REPLIES 4
Gonna need way more info.
I've worked on my file in Geomagic wrap, creating, wrongly different selections
Then, i've saved my file as STL and when i open it in meshmixer, i see those black spot.
Can you attach the .mix of one where this is occurring?
MagWeb
in reply to: andreasperti_2022
Might be just some rendering issue due to MM is set to render the mesh based on vertex normals by default. This shades sharp edges darker...
You might try this:
Press and hold Space to open MM's Hotbox > In its Mesh/Normals section click on the button in the middle which shows the facets of a sphere ...
Gunter Weber
Triangle Artisan
