Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Basic help to import an ASCII stl file into Meshmixer
1 REPLY 1
capowski
482 Views, 1 Reply
I'm new to 3D printing, and have written Java software to generate several
very simple ASCII files with the extension .stl.   My numbers look good, but
Meshmixer gives error messages when I try to import them.  Furthermore,
when I have NOT run Meshmixer, and write an STL file into any
disk directory, Meshmixer
applies its icon to the file listing of the directory.  I think the numbers in
my very simple files are correct, but I am not certain that their basic
Windows-level structure is.  Could someone please send me a very simple
ASCII stl file that works.  I am using a Windows 7 computer.  Thanks,
Joe Capowski, Chapel Hill, NC     capowski@email.unc.edu
1 REPLY 1
MagWeb
in reply to: capowski
Attached a minimal tetrahedron (4 faces only).
Opened in a text editor it looks like:
solid "Tetra"
  facet normal 0 -1 0
    outer loop
      vertex 0 5.96046447754e-08 -5.96046447754e-08
      vertex 10 5.96046447754e-08 -5.96046447754e-08
      vertex 5 5.96046447754e-08 8.xxx-xxxxxxxx
    endloop
  endfacet
  facet normal 0 0.333332687616 -0.942809283733
    outer loop
      vertex 5 8.xxx-xxxxxxxx 2.xxx-xxxxxxxx
    endloop
  endfacet
  facet normal -0.xxx-xxxxxxxx 0.333326369524 0.471416115761
    outer loop
    endloop
  endfacet
  facet normal 0.xxx-xxxxxxxx 0.333326369524 0.471416115761
    outer loop
    endloop
  endfacet
endsolid "Tetra"
This should load fine in MM
Gunter Weber
Triangle Artisan
