Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Autosave saves my 1.5GB file every minute. How can i stop it?
7 REPLIES 7
Message 1 of 8
g00220539
1813 Views, 7 Replies
I'm dealing with aligning several high-poly, textured meshes in one session, and Autosave is making it impossible to work. The autosave file is around 1.5 GB in size on average, which I expect. It takes like 45 seconds or moer to save the autosave, then it does it again a minute later. What the hell? I tried changing the meshmixer.ini in (my documents/meshmixer) to AutoSaveIntervalSeconds=9000 and don't know what the default is anymore.
7 REPLIES 7
Message 2 of 8
MagWeb
in reply to: g00220539
Editing the ini is the only way I know to change the AutoSave interval. You need to edit it while MM is shut down.
Default is 60 seconds. Means the ini line is:
AutoSaveIntervalSeconds=60
On WIN meshmixer.ini should be located at:
C:\Users\User Name\AppData\Roaming\Autodesk\meshmixer.ini
on MAC at:
~/.config/Autodesk/meshmixer.ini
(Note that AppData as well as .config are hidden by OS defaults)
You need to edit this file at that location not some file existing in documents/meshmixer
Gunter Weber
Triangle Artisan
Message 3 of 8
jamesbeckett73
in reply to: MagWeb
Just to add for those not familiar with Mac path finding:
Choose "Go to Folder" from the Finder's Go menu and put the path there.
" ~/.config/Autodesk/meshmixer.ini " as above from MagWeb,,
thanks a tonne, your king!!
Message 4 of 8
putnamto
i know this is really old but their is no "AutoSaveIntervalSeconds=60" inside of the ini file
Message 5 of 8
hfcandrew
in reply to: putnamto
It is about the 10th line down. Send a screen shot.
Message 6 of 8
putnamto
in reply to: hfcandrew
Message 7 of 8
hfcandrew
Yep its there...:
Message 8 of 8
putnamto
Now I feel like a dippy, thank you.
I was using notepads search feature and it wasn't finding anything.
