Hi everyone,
I am trying to attract a plane created from a honeycomb, to fit on the outside of a bowl.
My work flow to get to this point was the same as if I were to get text onto the bowl. Selecting the surface of the honeycomb, inverse, delete inverse, set bowl as target, select all of plane and then attract to target. The process begins, but doesn´t seem to make any progress at all, it stays in the computing stage and the progress bar stays gray. I´ve let it compute for an hour and nothing happened. I needed to kill MM in process explorer to get out of the program. The diameter of the bowl is larger than the diameter of the honeycomb, so it is not a to small a target.
Is what I am trying possible or am going about this all wrong?
