Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
AligntoStroke
2 REPLIES 2
norbertut
156 Views, 2 Replies
AligntoStroke
I've been trying to find out documentation of what AligntoStroke does.
This is a property under Sculpt - Surface operations.
I tried drawing on a sphere with this activated and deactivated and I do not see any difference.
Anyone has a clue of what this property does?
Thanks!
2 REPLIES 2
MagWeb
in reply to: norbertut
Like Spacing AlignToStroke refers to a Stencil. Let's say you use a stencil showing a white arrow pointing to the stencil's right and you use Spacing so one drop doesn't intersect the former one:
Disabled: The Stencil's direction doesn't change. From the start of the stroke the arrow always points to the right hand side of the scene.
Enabled: The Stencil follows the direction of the stroke. From the start of a stroke the applied arrow on the mesh points from its last drop towards the next.
Gunter Weber
Triangle Artisan
norbertut
Thank you!! 😁
I am amazed how many things can be done with Meshmixer, a pitty there is no more development.
I just was playing with Stencils yesterday and this could have been handy.
