Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
advanced rendering mode without graphic errors?
3 REPLIES 3
Sungod3000
340 Views, 3 Replies
im one of the adamant meshmixer users and I recently heard that it is still possible to use the normal (not basic) rendering mode.
When i disable basic rendering mode, keep the viewcube and keep the printer preview it works most of the time.
When I disable the printer preview I get this:
I heard that it is possible to somehow enable the normal rendering mode without graphic errors.
I also read the disabling the viewcube plays a role but when I do that, it doesnt change anything.
Has anyone managed to get a stable rendering mode?
Cheers
F.
3 REPLIES 3
Sungod3000
in reply to: Sungod3000
maybe there is a way to hack these printer previews, if one could find the template file for the an make on printer 1x1x1mm it wouldnt be in the way all the time.
MagWeb
Guess you're trying to hide the printer via Preferences/Printers >MakeNoneVisible???
Instead the proper way to hide a printer is: menu: View>ShowPrinterBed (Click it to remove the hook).
So: Select some printer (you might choose any if you don't have some) and hide it via the View menu
Gunter Weber
Triangle Artisan
hfcandrew
in reply to: MagWeb
omg you're right!
Mine crashes and does the same error when I do it via preferences. Sooooo many quirks of MM
