Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Advanced Boolean settings for mold
2 REPLIES 2
theebadge
368 Views, 2 Replies
Just making face mold using boolean difference.
How much do the advanced settings matter other than "max quality" and unchecking "auto reduce"?
I don't care about the outside edges so much as just making sure that the features of the person's negative face matches the positive.
2 REPLIES 2
MagWeb
in reply to: theebadge
Please check out the manual about Booleans
This is a nice explanation of the way MM's booleans work and what the different parameters do.
For a simple planar parting surface as in your case:
It's much easier and robust to use PlaneCut than using BooleanDifference.
  1. SelectAll of the face object and do Edit/FlipNormals
  2. EDIT/Combine face and a cuboid object. This cuboid needs to enclose the face object totally. This make the face a cavity inside the cuboid.
  3. Run EDIT/PlaneCut on the combined object and move the cutting plane to the desired position.
Gunter Weber
Triangle Artisan
theebadge
in reply to: MagWeb
Wow, was that ever easy and fast.  Thanks so much!
