Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Adding flat stl figure to a curved surface.
1 REPLY 1
jan-reri
1035 Views, 1 Reply
How can I get these two fishes to fit the curved surface in order to avoid any gap between these two stl objects?
1 REPLY 1
hfcandrew
in reply to: jan-reri
This option often fails with complex meshes, and can have no separated shells and only one boundary:
A] Select all>Convert To>Open Part>Meshmix>MyParts>Click and drag onto your location
This option will not be  perfectly 'curved', but you and curve it manually then extrude a base downward
B] Select about 1/4 of one side of the object>Soft Transform and set falloff the the half way point of the object>rotate the widget to deform one half into the curvature your desire>repeat on the other half>Select the bottom ring of of triangles by zooming in very close and double clicking on a single triangle>Transform and pull the arrow down. If you want it exact without the base sticking through then try the boolean tools.
