where is undo command in meshmixer ?
googled this and you tubed it, put undo into help menu found nothing, just where is the undo command in meshmixer ?
also just what are we supposed to pickk on the left hand side drop down box on this forum called prodect category, I see meshmixer in 'select a board' but nothing apprpriate at all in product category,
DBenz
You find step by step Undo (shortcut Ctrl+Z (Cmd+Z on MAC)) and Redo (shortcut Ctrl+Y (Cmd+Z)) in the Actions menu.
There's also Undo(SkipTools) and Redo(SkipTools) which undo all steps you made in a tool with a single click.
Netfabb is a Autodesk category (others are Fusion360, 3ds Max, AutoCAD, Maya a.s.o.) inside the Autodesk Knowledge Network.
Each category may have several boards. In case of Netfabb category there are two boards: Netfabb Forum and Meshmixer.
Now if you do a search for "Printer" via This category it returns results from Netfabb Forum AND Meshmixer boards.
If you're in the Meshmixer board and you search "Printer" via This board it returns results from the Meshmixer only.
