- Mute
- Permalink
- Report
I want to build a solid in Sketchup, but this comes with mistakes and it was no possible to repair withe an in Sketchup. So I try to repair this structure with Meshmixer.
Frist picture shows the current situation after importing the .stl file. A shell with hole an the border
Frist Attempt : use inspector to show the mistake, no results, on answer
Situation after importing stl File (sketchup) a shell with a hole at the border
Second attempt: Select the border and use "fill and erase"... Result: Hole is now closed, but not in the right location, at the edge to this shell is now a part of the shell is missing. This is not my aim, see screenshot
Attempt 1: result after using function fill and erase
Questions: I am looking in serval foreign, but I saw no solution ,
Thanks a lot for give me a hit, what is wrong in my operation? My understanding this problem with a regular geometric form was by very easy to solve with Meshmixer.
