sliding objects on each others
Hi dears, I am dentist when I have upper jaw object and lower jaw object and try to move them in away of lower forward movement it goes through the upper. is there away to make it slide and follow the shape of the other object. means not to go through.
hfcandrew
Not if you are just using the 'transform' tool.
For precise alignment read this: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-6AD70EE2-6EE4-4676-A35B-851894924FCE
no sir not that what I am looking for ( align), when I move an object and it contact another object it actually can penetrate it and pass through it. while it should be blocked and if further movemnt happened it should slide influenced by the shape of the other object
Sorry, MM doesn't support collision detection or other physics stuff...
thanks a lot
