Properly merging multiple .stl for 3d printing
Hi everyone, I'm pretty new to meshmixer and 3D modelling,
I'm trying to merge multiple parts of an action figure, to be able to 3D print it in a single session. The pieces are cut and have aligning pins to make assembling easier, so as an example there are holes in the torso to insert arms, legs and the head. The problem is that when I move the objects close to each other and then use the combine function, the holes are not filled and the pins tend to "sink" into each other. Is the only solution making it solid? I've already tried that and it drastically reduces the quality of the .STLs, even while setting it to "Accurate" and increasing mesh density and Solid Accuracy to the maximum. I've already tried to export the finished and "unsolided" model to a slicer software, and when looking inside of it I can clearly see that there's some void space between the holes and aligning pins, and some aligning pins are inside the torso; I'm pretty sure that those would make the print fail. Am I doing something wrong, or even skipping something that needs to be done? What can I exactly do?
Thanks in advance
EDIT: Just to make it clearer:
