models disappearing when more than one selected
RweyerQVKSY
RweyerQVKSY
hi.  just started having a few problems.  not sure if I'm in the right place or not, just saw posts about meshmixer errors.
-having issue with models disappearing when I have more than one selected in the object browser and try to move both models together.  they reappear if I move the mouse into the objects browser window or a command like transform, but will disappear again if I try to rotate.  I am able to work on a single model but I often work with more than one model per arch at a time.
-when I'm in select, the brush is now neon green, but that's not a big deal.
-this issue was better seen. not really sure what this is. it is happening now to stl files I have already worked on and printed so I know it is not a problem with a new file.
Screenshot 2024-07-17 091234.pngthis is the neon green i described with the select.this is the neon green i described with the select.
hfcandrew
Oh I've had this neon green glitch thing happen before, it ended up being a graphics card issue. Maybe try turning on basic rendering. (File>Preferences>EnableBasicRendering)
Some other threads reporting something similar:
https://forums.autodesk.com/t5/meshmixer/newbie-please-help-with-selection-tool-working/m-p/9887167
https://forums.autodesk.com/t5/meshmixer/select-tool-showing-green-area-larger-than-what-is-actually...
RweyerQVKSY
Thank you sooo much!!  Your second link someone suggested to turn off printer bed under view.   Fixed all of the issues I listed.
