Hi there,
i get from a 3rd party software several STL-Files which i have to modify in MM.
Always the same steps:
1) open file 🙂
2) hollow with wall thickness 2.5 mm
3) horizontal plane cut about 1/3 of the model height from the bottom (model is plane and horizontaly aligned)
4) save/export to another directory
Takes a lot of time and is boring, too!
I think there should be a solution that a task will take all files from the import directory one by one, performing the operations with MM and finally save the new STLs in my output dir.
Is such a repetive task makeable with AppleScript or only with the MM API (python or C++) ?
We have iMacs as well as Windows-PCs
And, i would pay for that script of course if a solution is to time consuming.
Best regards and thanks in advance
Karim
