Meshmixer not loading!
eniye9
eniye9
Working on a project and Meshmixer randomly froze. Restarted my laptop and since the restart the application is not opening or responding. I have uninstalled and reinstalled it numerous times. Can anybody help? Thanks in advance.
If MM did its job before you might try this while MM is down:
Delete the autosave folder (MM will create a new one at its next start):
If you did a standard installation the auto-save file is usually located here:
Windows: C:\Users\User Name\Documents\meshmixer\autosave
Mac: ~/Documents/meshmixer/autosave
And or:
Delete or rename  meshmixer.ini (MM will create a new one with default settings at its next start):
Windows: C:\Users\User Name\AppData\Roaming\Autodesk\meshmixer.ini
Mac: ~/.config/Autodesk/meshmixer.ini
(NOTE: AppData as well as .config is hidden by default, so you might have to enter that path manually or choose to show hidden files.)
paper1pr
Community Visitor
Community Visitor
I had to create an account just to thank you, I would have never figured this out on my own. It's been months since my meshmixer worked, deleting "meshmixer.ini" worked like a charm. Thanks so much!!!!
hezha_shafiq
Community Visitor
Community Visitor
Thank you so much you saved me
