Boolean differences and offsets
Message 1 of 13
I need some help. I have a dental Model (pink) and a dental splint(green) and an attachment that I need to add to the splint (purple). the problem is I need the splint to be offset from the tooth surface by .1mm. As you can see in the attached image you can see it works except for the area that that attachment is placed. how can I offset that area so i can have an accurate fitting splint? Screen Shot 2020-04-14 at 8.36.01 PM.png
Replies (12)
Message 2 of 13
hfcandrew
Before you do your boolean difference, scale your model bigger with an offset: Select all>Edit>Offset (Set distance to 0.1mm)
Message 3 of 13
Thanks for the suggestion, I tried that and I get this error.
Message 4 of 13
hfcandrew
Every mesh is so different, it is impossible to tell what the issue is without the .stls. can you post them? this tool can fail if it it not solid and has non-manifold pieces or flipped normals etc.
Message 5 of 13
I tried making the dental model a solid and still have the same issue.
Message 6 of 13
hfcandrew
Sorry, I always have trouble following what people want done.
Do want Shell {Max1}.stt to boolean union to purple piece in your original post? If so can you also attach that model?
Message 7 of 13
Sorry that was my bad I need to be the boolean difference between the shell and the remove undercuts model. I need the remove undercuts model to remove pieces of the shell model. does that help?
Message 8 of 13
hfcandrew
Are you sure to sent me the correct pair of models? The teeth looks nothing the same.boolean fail.png
And in complex geometry such as teeth it will make hundred of subtraction boundaries instead of like 2 or 3, thus more likely to fail.
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-355503DE-889B-4168-8398-084F9BBD508B
Also the order in which you select the objects matters, so for this you will want to select "Shell" then "undercut".
Message 9 of 13
ok lets try these two files. I need "teeth" to subtract shell.
Message 10 of 13
hfcandrew
This looks better, looks like it should work, but it is still failing. There are a few oddities in that 'shell' had any extra body in it. Go Edit>Separate Shells. So I deleted that chunk out, but it still failed.
Then also there are hole in the tips of the molars punched through on 'shell' tool but the tool doesn't even fail at those points anyways.
A good test to see if that model will work in any circumstance at all is to try to same operation but using a simple primative such as the sphere against both object. If a simple shape doesn't work for both objects, then using both objects together certainly will not work.
I can get a boolean subtraction to work with a sphere and 'teeth' but not for a sphere and 'shell'.
I'm stumped again! This looks like another job again for our resident MM superhero @Anonymous
Sorry my friend, I'm stuck too!
Message 11 of 13
@Anonymous
Run SeparateShells on your Shell object and discard the interior cavity object after that.
Run MakeSolid on the Teeth object. Switch to Accurate mode and set a higher SolidAccuracy and MeshDensity. Set OffsetDistance to the value the gap between Shell object and Teeth shall be finally:
SELECT the "contact surface" on your Shell object and Transform it to give a clear intersection towards the Teeth (the problem with Booleans are redundant surfaces resulting in a never ending number of intersections)
Now run BooleanDifference on Shell - Solid result:
Removing not needed particles there's a constant gap between Shell and Teeth now:
Message 12 of 13
I have  problems like Paul performing B-diff between dental model before and after wax-up.
I solidified scansion before trying B-diff
I inspect two different meshing and a lot of red and blue lines. (Unfortunately  I don't understand what red an blue line are! i think errors but i can't check)
If I accept  I had "tools error" window
suggestion?
Message 13 of 13
hfcandrew
Red lines show non-manifold triangles.
Blue lines show open boundaries.
These can be corrected with the inspector tool: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-83BC663B-FA1C-46D3-8C2F-82EB6892DFC3
Try that nad see if the above mentioned process works.
