Boolean difference leaving bumps
I'm trying to cut a hole on that object, but after playing around with the boolean difference that's the best/sharp cut I can get, it leaves some small bumps in the corners.
Any tips for this case ?
Simple trick:
If you do a BooleanDifference object A minus object B run EDIT/GenerateFaceGroups on object B first (defaults should do the job)
This hardens the edges for BooleanDifference.
Hi
Although it's not perfect it seems to get a better cut, still few minor bumps but i guess i can live with them.
