Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
unfold surface???
7 REPLIES 7
Message 1 of 8
1877 Views, 7 Replies
unfold surface???
Is there a way to take a cylinder, solid or surface but preferably solid, and unfold an edge to create somewhat of a sheet metal layout? I have to do a 2d visual layout of a 360 rotation and I was thinking I could create a cylinder, cut out the visually blocked areas and unfold the edge.
7 REPLIES 7
Message 2 of 8
JDMather
Can you post what you have so far?
Message 3 of 8
I don't really have anything yet. Cutting the cylinder kind of wastes time if I don't know how to unfold it. All I'd do for an example is just create a cylinder and make a slice into it at an angle.
Message 4 of 8
BTW - www.mymcad.com is down. Here is the lisp to use to change layers
easier in MDT.
Message 5 of 8
Sorry, wrong place.
Message 6 of 8
I found the AMCHLAY.LSP zip but it won't run because it indicates the dialog box is not present. How would I search for that?
Ed Galicki
Message 7 of 8
johnteng00
there is a solution from solid3dtech, it is called SmartUnfold. Attached is the short user guide.
eric
Message 8 of 8
hello sir,
      do you have this plugins? UNFOLDSURF
