Are you on Sp2? It sounds like the externalize issue that Sp2
resolved.
To fix, you must examine all the external files for the 1 culprit
file. It probably has a pattern on it. When you open that bad file,
you will see its quite empty.
An easy way to pin point it is to hide 1/2 the files from the assy at
a time. If the assy is OK, then youve narrowed your search by 1/2.
repeat unil its identified.
- drew
On Thu, 8 Feb 2001 04:17:04 -0800, "Ron Gibson"
wrote:
>I HAVE A PART DRAWING. BY ITSELF IT IS FINE AND I CAN EDIT IT. BUT WHEN I
>BRING IT INTO AN ASSEMBLY AND LOCALIZE IT IT AND THEN TRY TO EDIT IT SAYS
>FAILED TO ROLLBACK SKETCH FOR EDITING. OTHER PARTS IN THIS ASSEMBLY ALSO
>GIVE THIS ERROR. CAN SOMEONE HELP ME.
>RON GIBSON
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Check out my MDT FAQ @ http://mymcad.com/
