Announcements
Transparent background rendering alpha channel on vray
Hi everybody
I was done one ship model with glass,I need transparent glass with alpha channel on vray render. I took all file format like(Png,Tga,exr) but the alpha channel will not came properly it’ll came with full white I attach the render image RGB and Alpha image TGA file .
But alpha came once I hide the glass on layer but I need alpha channel without hideing glass please any one can help me ??
mspeer
Hi!
If there is an object you'll get a white alpha channel that's normal.
Render a separate layer or ID pass to get only the windows for compositing.
Hi, you need to change "affect channels" option to "color+alpha" or "all channels" under refraction advanced rollout in glass material attributes.
Or you can create vrayobjectproperties for glass object, and set alpha contribution to 0, under Matte Properties in vrayobjectproperties attributes.
Thank you so much it works
Great, glad to hear that!
Great
