Textures Not Showing Arnold 5 RenderView Also Grayscale
Problem 1: I am using a color checker map similar to this one and the colors won't show up.
Problem 2: The texture I'm using shows up with the lambert shader, but not when I use aiStandardSurface. It seems invisible. See the pic with the pink plane.
I've searched everywhere and can't find the problem.
Stephen.Blair
problem 2) the texture is connected to the weight, not the color, of the Standard Surface
// Stephen Blair
// Arnold Renderer Support
Thanks so much. That was actually the problem on both issues. So simple, but so illusive.
