textures are not displayed on copied mesh.
velariakrah2002
velariakrah2002
Hi.
1) I copied the mesh
2) I edited the copied mesh (removed unnecessary faces, moved vertices)
3) Textures disappeared from the copied mesh.
In the UV editor everything is normal, in the hypershade  everything is also normal. Maybe there are some problems in the node editor? But the texture is not displayed, only the average color on the model is displayed. If you replace the texture with a black and white checker, then either black or white color will be displayed on the model. I tried deleting the shader and assigning a new one, but it doesn't help.
velariakrah2002
I assigned a texture to a normal cube and it displays normally. The mesh only displays the texture tint, what's the problem?QUBE.PNG
velariakrah2002
damaggio
How did you create a second UV set?
