Skydome problem
Skydome problem
wilybros
Skydome problem
wilybros
Community Visitor
Community Visitor
Hey guys, so i've started to make a skydome and add stars to it but whenever i add lambert to a skydome texture for stars, whenever i pull up UV editing, nothing shows where i can use the shell to stretch it out. Please help. I'm basically trying to stretch the texture so it doesn't distort or pixelate. I'm using HDR space file btw. Thanks
mspeer
Hi!
The SkyDomeLight is not a polygon object, so there are no UVs you can edit.
Please create any Polygon object like a polygon sphere and add the texture there, if you want to edit UVs.
(You could also edit the texture in an image editing application instead).
mspeer
-duplicate- (deleted)
