Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Shadowmatte issues - canno't see the entire shadow
2 REPLIES 2
mimmio89
473 Views, 2 Replies
Hi there,
I'm trying to cast a shadow on a plane and on some pebbles.
On the plane everything ok, but on the pebbles I can cast only the faces looking  towards the light, the back part of the pebbles doesn't caught any shadows.. I've tryed to on off the shelf shadows, the cast shadows too but nothing..
Im using arnold and maya
Thanks in advance
Best
MM
2 REPLIES 2
lms2k
in reply to: mimmio89
Are you using the shadow matte shader or the AOV?
Also do you have pictures of the issue.
mimmio89
in reply to: lms2k
Thanks for the quick reply, I'm using the shader, anyway I've solved the problem.
In the shadowmatte shader you have to put the backlight to 1.
Best
Mimmio89
