Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Render setup shader override not working on all materials
0 REPLIES 0
Message 1 of 1
341 Views, 0 Replies
basically, I put lambert in surface shader slot for viewport texture visibility because I am not able to see textures on the viewport after using aicolorcorrect. so I put lambert in the SurfaceShader slot of the shader engine, & i put AiStandardSurface into the aiSurfaceShader slot of the same Shader engine. But after doing this. i want to shader matt all objects.  but Render setup cant be able to select the materials which are connected to a surfaceshader slot. they are only able to override ShaderMatt whos connected only to the AiSurfaceShader slot.
0 REPLIES 0
