Render past 4K/ 4K with 300 resolution
mhardingTMPVZ
mhardingTMPVZ
I am having trouble with finding a solution rendering past 4K without the computer crashing or taking way too long. I want to render an image of 4K with 300 resolution but i understand that Maya cant render past 72 res. Is there a way to break the render up into sections for example render the top left then right etc and stitch them back together? I need to renders to be high quality for print purposes. Open to any suggestions 🙂 Thanks
(Im using Arnold)
Christoph_Schaedl
Rendered images are measured in pixel.
Printed images are measaured in pixel/inch wich irrelevant during rendering.
Do some research in that direction.
https://linktr.ee/cg_oglu
mhardingTMPVZ
Thank you! I will look into this more
