Redshift renderer not updating XGen modifications
Message 1 of 1
I'm a student who uses Redshift and I've encountered a very annoying problem when it comes to using the IPR and XGen.
I'm at the end of my project and all I have left to do is add hair and fur, so I create my description add guides,clumps, noises, etc...
Then, when I'm happy with what I see in the viewport, I open the Redshift IPR (not having opened it before) to see how it looks rendered.
The IPR opens up, does it's thing and everything is there, looking good.
Then, I decide that the hair is too thick, not dense enough or needs an extra clump, so I make the necessary modifications. These modifications appear in the viewport, but the IPR doesn't take notice of them, even if I close it and open it up again.
I've tried fiddling around with it a bit, but the only solution I've found so far is to reload the entire scene by opening it up again. Which is starting to become a real pain in the neck.
If anyone knows how to fix this problem I would be so grateful!
Thank you!
(I use MAYA 2018 and Redshift v.2.6.41)
Replies (0)
