Redshift Problem - Red Shader after batch render
Hello everybody,
I have an annoying problem. I cached a rolling animation for two dices (please find a pic attached). If I do a first batch render of a sequence, the render works properly. If I do a new batch render, cached objects become red. To solve the problem I have to delete the cache and then import it again. I can't figure out how to solve definitely. Any suggestion?
Redshift 2.6.19
Maya 2018
sean.heasley
Hi @Anonymous and welcome to the community!
Is your Maya 2018 up to date?
Also have you tried unloading and reloading the Redshift plugin?
Finally, what happens if you use a different renderer like Arnold?
I will update in few days both maya and redshift, just enough time to have new Redshift Key from my IT.
However, It works properly with Arnold. I did a reload as you said and it seems to work now. I'll do a render during night and see what happen tomorrow.
sean.heasley
Hi @Anonymous
Sounds good! I'll keep an eye on this thread and check in with you tomorrow unless you get back to me before then!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
