Problems with rendering chrome material
abankstonRAS
Message 1 of 19
abankstonRAS
I'm trying to render a metal hook with a chrome material, but the renders look flat in some spots and reflections in other areas look too dark.  It makes the item look like a drawing, rather than photorealistic. I'm using the 2020 version of Maya and rendering with Arnold.  What settings can I change to get a better result?
Replies (18)
Message 2 of 19
damaggio
Just use Arnold chrome preset.
chrome will reflect whatever is in your environment set up and lighting.
the settings are not in the shader necessarily.
Message 3 of 19
@damaggio, do you use both V-Ray and Arnold?
Message 4 of 19
damaggio
Vray only.
Message 5 of 19
abankstonRAS
What other settings should I try?  I have to render on a totally white background, so I'm using AIrayswitch, an area light, and a skydome light.  Initially, I tried rendering with a backdrop, but it was giving me an off-white background, no matter what I tried.
Message 6 of 19
damaggio
Your render is correct with a white background, if you want to make more interesting then the environment has to be more interesting, white background is not a good choice here, chrome is the same as mirror.
try a studio light HDRI instead.
Message 7 of 19
abankstonRAS
So this is probably the best I'm going to get with an all white background?  I would change the environment, but it's going to be used as a product image and has to be on all white.  Would you recommend rendering with a backdrop and then removing the off-white background in post?
Message 8 of 19
damaggio
Just edited my answer above.
Message 9 of 19
abankstonRAS
Mostly my problem is that I don't like how dark the reflections are on it.  It doesn't feel photorealistic to me.
Message 10 of 19
abankstonRAS
Thank you!  I'll try a studio light hdri and report back.
Message 11 of 19
damaggio
Use an studio HDR like real photographers do for product photograph.
Message 12 of 19
abankstonRAS
Ok, so the studio hdri definitely improved the flatness issue, but I still have the issue with those dark lines.  What is that, and how do I soften it, so it doesn't look so cartoonish?
Message 13 of 19
damaggio
Those dark lines are either on the hdr image or your ray trace settings. I can’t tell without a scene file.
Message 14 of 19
abankstonRAS
I'm guessing they must be in the ray trace settings, but I'm not sure what to adjust.  Not sure if I can share the scene file since it's a proprietary design.
Message 15 of 19
damaggio
Read in the documentation about raytracing in render settings, in lights and in shaders.
I ‘m on location now and won’t be available till tomorrow.
Message 16 of 19
abankstonRAS
Will do.  Thank you for all of your help!
Message 17 of 19
abankstonRAS
Just a quick update.  I think I've got it worked out.  Thank you again for helping me!
Message 18 of 19
That came out nice!
Message 19 of 19
abankstonRAS
Thank you!
