problem rendering bump map with arnold
khanwars64
Message 1 of 10
khanwars64
hello
first of all sry for my weak english
im trying to achive a scene with bump map with arnold   but the result is more like a color map
in compare of mentel ray
( bump depth effect is very very low like nothing)
also im trying to use bump map+normal map as same as your guide in this page
https://support.solidangle.com/display/AFMUG/Combining+Normal+and+Bump+Maps
but the result isnt even close to what it  shuld be
actully the bump map kill the normal map  and scene will be like a color map
note : test scene is a  poly plane + directional light/aria light+chekcer/bulge as bump map
Replies (9)
Message 2 of 10
khanwars64
ZzzZZZzzZzZ
im waiting for answer
Message 3 of 10
Stephen.Blair
Hi
Procedural textures like checker and bulge aren't working with bump2d, that's a known issue.
bulge does work with aiBump2d
Stephen
Solid Angle Support
// Stephen Blair
// Arnold Renderer Support
Message 4 of 10
Hope you don't wait to long for free help, in the mean time try a displacement shader instead of bump, Arnold is next gen, bump is old school. Convert your displacement to texture, then reapply as texture with tangent normal's as bump. This will give you better results than bump. good luck.
Message 5 of 10
khanwars64
if you pay attention to my post there are more parts. actually those are main  parts
Procedural textures  are just example
btw  even with the aibump2d  i couldnt achive bump with bulge here is my scene if u want to check
note : if my english isnt good enough to make my  point   let me know
Message 6 of 10
khanwars64
tnx for help
i  did  😉
i did not understand this part
(Convert your displacement to texture, then reapply as texture with tangent normal's as bump. This will give you better results than bump. good luck.)
what u mean buy convert displacement to texture?  and  the reaply  with tangent normal as bump ?  u mean  normal map ? or i m missing  something
right now   im using a black and white  map  for bump  or displace  and its kinda working for  displacement eithr
but there is some sort  of issue    when  im trying to reapat   uvs   or the normal map and displacement map
there a shift between  here is a example
 in this case i repeat both normal map and displacement   uvs for 3 time
left side is displacement map right side is normal map
even some times  scale of displacement /normal map  will change with my camera move  in scene
Message 7 of 10
Ok your problem was that you connected your bump incorrectly. the easy way to do this is to select your aistandard material, go down to the bump mapping tab, just underneath the reflection and refraction tab, click on the add node icon and select your arnold aibump2d Node. Then Select add node on the bumpmap options and choose your bulge. Increase the height and that should do the job.
Message 8 of 10
khanwars64
thank you so mush now bump and depth working very well
i was folowing this guide  https://support.solidangle.com/display/AFMUG/Bump2d      i think they should change it.  second bump node will make it work
now only a little problem left
as i said when im trying to use a displacement map in a very large scale scene like  in the photo (in this case 5000 cm ) some messy  will happen
displacement must be as same as it is in center of photo. but as you see its weird in  sides
Message 9 of 10
Looks to me like your displacement map Uv's aren't right upload your scene again, ill have a look. could be a number of things, but I think its a scale problem with your mapping.
Message 10 of 10
khanwars64
its  a simple plane  i think itsnot uvs problem
must be something in scale  or camera   idk
im using centimeter system for scale
