Problem in using Render Proxy
Message 1 of 22
Hello
I modelled a simple pot in Autodesk Maya 2015. Now I need to use pot multiple times in a scene. When I try to import it in my scene using Render Proxy the object goes missing. Attached image shows the following problem with the scene. Same render proxy file linked but render is not proper. Unable to understand why is this occurring.
Any assistance???
Replies (21)
Message 2 of 22
damaggio
Hi, double check your set up by following these steps again, maybe you missed something........
Message 3 of 22
hi,
The output is still the same... 😞
not proper render. a single material has been applied to the object. Its a whole single mesh.
>freezed
>centered (0,0,0)
>history cleaned
>clean up done
yet its problematic
Message 4 of 22
J450NP13
Just to check...did you check to see if your normal's are reversed...I know its a long shot...but I had an object before look like that...and some faces normal's were reversed.
Message 5 of 22
How should I check about normals are reversed or not ??? Please let me know the procedure buddy ..
Message 6 of 22
J450NP13
You'll have to check the original object you made into a proxy.
What I do is turn off two sided lighting in the lighting tab of the viewport.....If the face facing you is black it will need to be reversed....When rendering reversed faces will not be visible....select the face and go to the polygon shelf and the normals tab and select reverse.
Message 7 of 22
As per said I turned off the two sided lights and none of the faces have normals reversed...
while using render proxy does any changes to be made in render settings?? I mean final gathering or GI or render quality...
I tried to use proxy in new scene. Still the problem persists.
Message 8 of 22
J450NP13
No settings need to be set...You're using mental ray correct?
Message 9 of 22
YES ...
Message 10 of 22
J450NP13
Send me an FBX of your pot.
Message 11 of 22
J450NP13
Or just the scene...I have 2015 too
Message 12 of 22
here is the fbx...
Message 13 of 22
J450NP13
Send me the original scene file.
Message 14 of 22
here is the original file
Message 15 of 22
pshwayka
Try this:
  1. Export your object as an OBJ file. (Make sure you have Materials enabled under the file type specific options.)
  2. Create a new scene.
  3. Import the OBJ file you just saved. Note: you may have to set the color for your Mia Material X again.
  4. Save the scene
  5. Export your object as a mental ray proxy
  6. Open a new scene and follow the instructions as per @damaggio 's post.
Not sure why this works, but it did for me when I tried it on your scene.
Message 16 of 22
damaggio
Didn't have any issues with the file, Windows 7 Maya 2016 SP6.
Message 17 of 22
J450NP13
Sorry I didn't get back sooner..I'm at work....I didn't have an issue with it either.
Message 18 of 22
pshwayka
Okay...I figured out an easier way to fix your file. Go into your Maya preferences and in the Settings section, change the working units to centimeter...then re-export your Mental Ray proxy file.
(Your file has the units set to inch, and I think that's what is causing the strange renders.)
Message 19 of 22
Thanks a lot... the issue is solved.
The unit in inches was making the error. Now its all good. Finally a step forward . have a nice day ahead 🙂
Message 20 of 22
thanks. the issue was with the units ..
now its solved
